Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2020-02-04T05:58:57+00:00
    Very Very good, thanks Markus
    i was try n succes good job markus 100% five stars for you
    2020-02-03T21:15:10+00:00
    you can try these first. uninstall K daniel drivers, and then instal fresh drivers
    2020-02-03T05:14:55+00:00
    First of all tnx mmmarkuss on this, your my hero bro \m/
    step by step:
    1. uninstall any daniel K pack drivers from your computer
    2. restart your PC
    3. install daniel K pack drivers (i choose full install) and restart your computer
    4. if you don`t have 7-zip program (for unziping doc.) install    ---> https://www.7-zip.org/
    5. download latest drivers from creative site ---> https://support.creative.com/downloads/welcome.aspx?nDriverType=1#type\_1
    6. unzip downloaded creative drivers file with 7-zip (right click and select "extract here..")
    7. find folder "Audio\DriversWin10\wdm" (from mmmarkuss post)
    8. rights click on "wdma_emu.inf" file and simply select install
    after that just restart your PC and that`s all.
    Work perfectly!
    Tnx again Markus
    cheers :)
    I have the Audigy 2 ZS with the extra drive bay installed in the front of my case with the extra auto in/out ports (though not being used).
    When I upgraded from Win 7 to Win 10 build 19041.21 (and now 19555- fast ring) the card had no sound with my speakers connected to the standard out port on the back. So all I did was download the other Audigy drivers from Creative and use 7zip to extract the file and install the .inf file - and the audio out works. I didn't remove the all divers or install the Daniel K files from
    http://danielkawakami.blogspot.com/2017/01/sb-audigy-series-support-pack-62.html
    2020-02-01T07:11:02+00:00
    Спасибо, всё работает.
