Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
  1. Deleted
    2020-01-14T17:22:41+00:00
    First of all tnx mmmarkuss on this, your my hero bro \m/
    step by step:
    1. uninstall any daniel K pack drivers from your computer
    2. restart your PC
    3. install daniel K pack drivers (i choose full install) and restart your computer
    4. if you don`t have 7-zip program (for unziping doc.) install    ---> https://www.7-zip.org/
    5. download latest drivers from creative site ---> https://support.creative.com/downloads/welcome.aspx?nDriverType=1#type\_1
    6. unzip downloaded creative drivers file with 7-zip (right click and select "extract here..")
    7. find folder "Audio\DriversWin10\wdm" (from mmmarkuss post)
    8. rights click on "wdma_emu.inf" file and simply select install
    after that just restart your PC and that`s all.
    Work perfectly!
    Tnx again Markus
    cheers :)
    2020-01-12T01:53:28+00:00
    Hi!
    Extract all files
    Restart and enjoy!
    Best regards!
    Markus
     Markus!  I cannot thank you enough!  Not only did you save me $100 but I didn't have it to spend and would've been soundless.  Thank you so much!  You are a smart guy!  Have a terrific New Year and God Bless you.
    2020-01-06T10:17:06+00:00
    It works
    Thank you
