:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
2018-12-08T04:47:30+00:00
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
    2018-12-09T07:29:42+00:00
    I did it, I still have a problem
    2018-12-08T15:11:46+00:00
    Through minidumps, it is not coming out. However, you can try to update BIOS, Display Drivers and Network drivers and see. You have already undertaken standard steps for Power.
    2018-12-08T15:05:21+00:00
    I suggest you to Run memory test for at least 8 passes, prefarably Overnight.
    https://www.tenforums.com/tutorials/14201-memte...
    If you have a DDR4 RAM, use MemTest86 rather than MemTest86+
    https://www.memtest86.com/
    When the test completes post back the Image(You can use your phone's camera).
    Disclaimer:
    There are links to non-Microsoft websites which would provide accurate and safe information. Watch out for ads on the sites which are frequently classified as a PUP (Potentially Unwanted Products). There is no need to buy paid products to fix your computers as they do more harm than good sometimes.
    2018-12-08T13:17:19+00:00
    Error code says "collecting some error info, then we 'll restart for you" also says 100% complete .  Do I just wait as it appears nothing is happening or do I do something?
    2018-12-08T12:07:32+00:00
    I do, what do you think is not a motherboard or power problem?
