Had you enabled driver verifier?
:( Your PC ran into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA
I have a problem when I started using a new graphics card gts 750ti restarts my computer and shows: (Your PC has run into a problem and needs to restart stop code: PAGE FAULT IN NONPAGED AREA does not always write PAGE FAULT IN NONPAGED AREA, but this is most often written, also This also shows when I restart my computer, when I remove the graphics from the computer I do not have this problem, I tried with a new graphics card, I still have a problem, do you have any solution? thanks
2018-12-08T11:15:15+00:00 -
2018-12-08T11:14:18+00:00 Windows is updated
2018-12-08T11:11:11+00:00 A. Analysis Results
- File Name: 120818-9843-01.dmp
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
IMAGE_NAME: CLASSPNP.SYS
- File Name: 120818-10093-01.dmp
PAGE_FAULT_IN_NONPAGED_AREA (50)
IMAGE_NAME: CLFS.SYS
*** ERROR: Module load completed but symbols could not be loaded for WdFilter.sys
- File Name: 120818-10671-01.dmp
IRQL_NOT_LESS_OR_EQUAL (a)
IMAGE_NAME: ntkrnlmp.exe
- File Name: 120818-10875-01.dmp
*** WARNING: Unable to verify checksum for win32k.sys
- File Name: 120818-13250-01.dmp
B. Third Party Drivers
None
C. Recommendations
Only Windows drivers are coming no third party driver.
Windows Key+i > Update & security > Check for updates and update your Windows
2018-12-08T11:00:19+00:00 I do not know what the problem is when I get the graphic I do not have a problem and I know that the graphic is correct, I tried it with another https://1drv.ms/u/s!AszrGIm2cM6CeiGMHDm96qaa5r4
2018-12-08T10:55:44+00:00 Hi,
I get the item isn't found. Are you sure you shared it?
