260ci WIA Driver USB problem
2018-04-18T16:58:51+00:00
What is this?  Under device manager, Imaging Devices,  shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
DaveM121 936.3K Reputation points Independent Advisor
2018-04-18T18:11:29+00:00
Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
40 additional answers
    2019-06-05T19:19:00+00:00
    I've got the same thing popping up and I have an HP all-in-one. Never even heard of Kyocera, so I'm with you on it being inadvertantly introduced by Windows update. Thanks for the fix because I tend to obssess terribly over these little tweaks until I can get it fixed. You rock LOL.
    2019-03-25T07:32:20+00:00
    Hi Winnie5560,
    Thank you very much. I Had the same problem with Winnie5560.
    And the solution of your answer had solved it.
    I'm really glad to thanks to you very much for your answer.
    2019-03-05T17:49:49+00:00
    usb\vid_0482&pid_061d&mi_01
    2019-01-29T03:38:40+00:00
    ayudenme la webcam no me agarra me dice error dee codigo 10
