Device Census Stopped Working Problem
2018-06-22T23:16:47+00:00
I have recently noticed when viewing my reliability monitor that every day around the same time 3 am - 4 am, windows shows that a program called "devicecensus.exe" has stopped working and notes it as a "critical event". My question is should I be worried about this and if so what are the potential fixes? Also is this application an integral part of Windows and if I delete it from System32 will it have an effect on my PC in any shape or form?
Thanks in advance for the responses and here are some of the error details if it helps:
Problem signature
Problem Event Name: APPCRASH
Application Name: devicecensus.exe
Application Version: 10.0.17134.1
Application Timestamp: 79a09a4b
Fault Module Name: WaaSAssessment.dll
Fault Module Version: 10.0.17134.1
Fault Module Timestamp: b7ab6594
Exception Code: c0000005
Exception Offset: 0000000000008ee5
OS Version: 10.0.17134.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 91f2
Additional Information 2: 91f294f44a03f9fda838805399465eda
Additional Information 3: ada5
Additional Information 4: ada50e612b0ea4dc151ec1a740a42603
Files that help describe the problem
WERInternalMetadata.xml
    2018-07-24T00:47:39+00:00
    Is device census only related with webcam or with all other devices' drivers such as, graphic, printer, or wi-fi/wired NIC, etc?
    2018-07-23T12:51:45+00:00
    No. If it were, every Windows 10 computer in the world would have been affected.
    I have decided to reset one of my affected devices and see if it'll fix the problem. So far, I've only seen this problem on machines that have been updated from v1709.
    2018-07-23T02:42:56+00:00
    Is this what causing device-census related errors?
    2018-07-22T23:33:38+00:00
    Getting this error on all win10 pc's running 1803, so something 6/28/2018 when it started.
    Log Name:      Application
    Source:        Application Error
    Date:          7/22/2018 5:04:58 PM
    Event ID:      1000
    Task Category: (100)
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      DESKTOP-C7MSO9M
    Description:
    Faulting application name: devicecensus.exe, version: 10.0.17673.1005, time stamp: 0x79a09a4b
    Faulting module name: WaaSAssessment.dll, version: 10.0.17134.1, time stamp: 0xb7ab6594
    Exception code: 0xc0000005
    Fault offset: 0x0000000000008ee5
    Faulting process id: 0x2e34
    Faulting application start time: 0x01d422104b581eb4
    Faulting application path: C:\WINDOWS\system32\devicecensus.exe
    Faulting module path: C:\Windows\System32\WaaSAssessment.dll
    Report Id: 75d6d06e-0774-49ed-8713-dd95fe56a512
    Faulting package full name:
    Faulting package-relative application ID:
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="Application Error" />
        <EventID Qualifiers="0">1000</EventID>
        <Level>2</Level>
        <Task>100</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2018-07-22T23:04:58.926384000Z" />
        <EventRecordID>3256</EventRecordID>
        <Channel>Application</Channel>
        <Computer>DESKTOP-C7MSO9M</Computer>
        <Security />
      </System>
      <EventData>
        <Data>devicecensus.exe</Data>
        <Data>10.0.17673.1005</Data>
        <Data>79a09a4b</Data>
        <Data>WaaSAssessment.dll</Data>
        <Data>10.0.17134.1</Data>
        <Data>b7ab6594</Data>
        <Data>c0000005</Data>
        <Data>0000000000008ee5</Data>
        <Data>2e34</Data>
        <Data>01d422104b581eb4</Data>
        <Data>C:\WINDOWS\system32\devicecensus.exe</Data>
        <Data>C:\Windows\System32\WaaSAssessment.dll</Data>
        <Data>75d6d06e-0774-49ed-8713-dd95fe56a512</Data>
        <Data>
        </Data>
        <Data>
        </Data>
      </EventData>
    </Event>
    2018-07-12T13:19:54+00:00
    I installed the latest cumulative update that was released on Tuesday with patch level 17134.165 but the daily crash has not been fixed together with other Windows 10 April 2018 update problems such as some mkv video files cannot have their thumbnails generated in File Explorer unless a thumbnail generator like Icaros thumbnails is installed. The videos play well but most of their details are not loaded when right clicking the file and navigating to the details tab. Icaros thumbnails also loads the details in the details tab.
