Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2014-01-23T15:10:55+00:00
    Well, for me, this is a viable workaround so I just put it out there in case it might be helpful to somebody else. Thanks for replying.
    2014-01-22T21:08:21+00:00
    No they dont do different things, and shutdown is something complete different than Hibernate or Sleep... And saying "do a shutdown and it fixes it" is complete nonsense, of course it will fix it for a short time o0 because it will reconnect/load drivers new. It's same as deactivating wifi card and activating it again (no, not over the wifi slider in metro ui, but in the wifi adapters list). Like I said, the dell drivers are b***s***, like the Intel drivers were some time ago (google intel 6235 connectivity issues). If your router really just has b/g (54mb/s), than still it can be the reason and you should get yourself a new one running OpenWRT for example.
    Also: bluetooth doesnt work correctly if you use 2,4ghz with the Venue. My bluetooth mouse lags and becomes instable. If you switch to 5ghzt it is working.
    2014-01-22T20:45:54+00:00
    Thanks for the reply and I agree with you that it shouldn't make any difference how you issue the shutdown command (to clarify, I was doing a complete shutdown not just sleep or hibernate.) which is why I was interested in whether other people could replicate the behavior. As I said it appears to be just a workaround and not a fix.
    Thanks for the heads up about the N wireless setting but, in my case, I only have a G class router so it doesn't apply in my situation.
    The only thing that leads me to suspect that the different shutdown buttons do different things (crazy I know) is that the perfect predictability of the two shutdown methods. I know what will happen to the wifi depending on how I shutdown.
    I remember there used to be an issue with the original Surface RT when shutting down. The system would be in Mute when powered back on. A patch fixed that. This has the same feel...but let's see if it happens for anybody else.
    2014-01-22T18:16:04+00:00
    Try shutting down using the windows 8.1 start button shutdown instead of the settings charm. It seems to provide a workaround.
    After a couple of days experimenting, I am able to control whether or not the WiFi goes into Limited connection when the Venue has been shut down.
    If I shutdown the unit through the Charms menu, it will not reconnect to my wifi when powering on.
    BUT, if I shutdown using the "Start" button menu, the Venue will connect completely to the router even if the tablet has been off over night and NOT plugged into the charger. It also works if the Venue was plugged in.
    Why should there be this difference and does this constitute a valid workaround for the WiFi issue?
    what do other people find?
    Charm and "start menu" are the same... o_0 That doesnt make sense what you wrote. Also, what do you mean by shutting down? Hibernate? Complete off? You should disable hibernate (powercfg -h off) and just use the "connected standy" mode, my Venue has a battery discharge rate of 0.37% per hour in connected standby mode, and that's good for me.
    Also, Ive tested into this problem again, and it's totally clear for me: It is working without any problem with 2,4ghz b/g mode. And the problem just happens with N mode, both 2,4ghz and 5ghz. If you set your router to just use b/g mode (55mb/s), it stays stable. If you activate N mode, the Venue becomes instable at some point (limited connectivity aka no internet, but it is still connected to the router).
