Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2016-06-12T05:01:31+00:00
    Thank you for the reply.
    I appreciate your patience and time.
    Did you try preventing any driver update which may be causing the issue?
    Please refer this article and check.
    Refer:
    Windows updates affecting WiFi performance on Venue 8 Pro and Venue 11 Pro 5130 tablets
    http://www.dell.com/support/article/us/en/19/SLN288089/EN
    Note: Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
    I hope this information helps.
    Thank you
