Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2016-01-16T15:14:29+00:00
    Did you do anything in particular? Did you try reinstalling those three updates everyone talks about? Or was it just a complete coincidence that it happened to end up working all on its own?
    2016-01-15T16:17:25+00:00
    Oddly mine is OK now - I had to go back to Win 8.1 on the Venue - W10 was hopeless - even the blue tooth mouse wouldn't work - One of the many updates seems to have solved the WiFi issue and its working ok - fingers crossed it stays that way.......
    g3tk
    I think it is, I have same on my 8 pro, can you let me know how to deactivate and reactivate the adapter as mine just died after the first standby (I got the tablet an hour ago and already it has died). Thanks!
    2016-01-15T15:23:39+00:00
    I've just gone through step by step trying this fix to no avail. I still wake my tablet from sleep mode after a few minutes only to find that the WiFi adapter is not working.
    Has anyone else found another solution at all other than this? Dealing with Dell is completely pointless, they actually told me that their team knows the tablet to be completely problem-free on Windows 8.1 or 10.
    2015-10-04T22:18:55+00:00
    I wish somebody had posted a warning the issues upgrading windows 8 to 10 associated w/ Dell pro 8. After finally figuring I had to update Bios etc... then the wifi issue popped up.
    Thx for the quick fix. I think you prevented a violent **** my Dell pro 8. lol
    It worked right away after I restarted the tablet.
