WiFi Connection Issues: 5Ghz band not found? How do I determine wifi settings & limitations
2014-01-02T23:30:50+00:00
Bought a new laptop and have been setting it up with a wifi dual band router.  My issue is that Band A at 2.5Ghz connects anywhere in the house, but the 5Ghz band cannot even be found.  Working the problem with my router settings and support.
Laptop: HP Pavillion TS 15 Notebook 15-n088ca with Windows 8.1 (fully updated) & WiFi
Router: D-Link Wireless AC1000 Dual Band Router DIR-820L with 2.5GHz and 5GHz bands.
The 2.5ghz band is discoverable and connects fine, and works anywhere in the house. The 5GHz Band is not even discovered, doesn't show up on the list. [A new Galaxy Tablet did find the 5GHz Band but was very weak].
How do I find out if there are limitations on my Notebook pc regarding 5GHz bands? Can they be updated? Are there other solutions?
I have been on the Router support site, and one of the issues mentioned was a limitation on the pc to recieve 5GHz. (Which I wish I knew before I bought the router at the same time as the pc)
Any help would be appreciated, Thank You.
2014-01-03T15:31:24+00:00
Hi Richard,
I have searched for information about the wireless adapter installed in your computer and found that your wireless adapter has 802.11n standard, which supports 5GHz bandwidth.
unfortunately, I was unable to find the Wireless adapter make and model. Let us know the make and model of the Wireless adapter.
While you reply, check if these settings help.
  1. Go to Desktop mode
  2. Select Charms > Settings > PC Info
  3. Click Device Manager (located in the top left of screen)
  4. Click the > sign to expand the Network adapters entry.
  5. Right-click the wireless adapter and click Properties.
  6. Click the Advanced tab, click 802.11n mode, under value Select Enable.
Hope the information provided is helpful. Do reply, if you need further help.
54 additional answers
    2017-07-26T00:35:28+00:00
    I use a **** model DG2460 dual band and cannot find the 5.0 band displayed for selection/assignment. The Internet supplier in Cox.
    2017-06-09T18:02:43+00:00
    Hi Richard,
    my laptop doesn't have an option saying 802.11n
    2017-03-06T03:56:18+00:00
    hello folks
    i did whatever directed here but still no effect.
    2016-10-09T13:55:01+00:00
    Hi Babu,
    My problem is: Using w8,1 can't found  (if ssid hidden) and connect to 5GHZ network.
    My Lap is a DELL VOSTRO WITH THE LATEST wireless drviver "Dell Wireless 1702 802.11b/g/n version 3.0.1.155.
    I did the steps 1 to 6 but on step 6 a can see only "802.11b Preamble Valur= Log and short"
    hi wilson Dias,
    i have same issue, thing is my Wifi hardware is same as yours b/g/n. i found that it doeasn't support 5.0 Ghz.
