Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2014-08-01T04:27:24+00:00
    My Lenovo S400 had the correct registry entries, but it was still not working. Found this utility and it fixes it and even two finger scrolling works now.
    http://www.intowindows.com/how-to-enable-two-finger-tap-for-right-click-in-windows/
    https://code.google.com/p/two-finger-scroll/downloads/list
    2014-05-06T00:33:30+00:00
    Good Luck!
    Two finger tap right click context menu running properly on my "Yoga 13 Win 8.1 64 bit" with newest "ootp18ww.exe" from Lenovo site. Swipe as well.
    I had to change up some from above to make it work so here is what worked for me.
    1 Press "win+R" for the run menu then type "regedit" then hit "enter"
    2 Navigate to: HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
    3 I used "2" for the value in "2FingerTapAction"
    4 I cleared the previous value from "2FingerTapPluginID" and inserted "SynTP"
    5 I changed the value in "MultiFingerTapFlags" to "3"
    6 reboot
    Good luck I hope this works for you
    2014-05-01T05:27:11+00:00
    I have HP Envy and got the same issue. The problem is that the synaptics settings doesn't get updated to registry. Finally I was able to fix it. HEre is the video
    https://www.youtube.com/watch?v=QUaKrOVScIE
