Two finger right click does not work
2013-10-18T16:17:22+00:00
I recently installed Windows 8.1 and the two finger right click gesture on my touchpad stopped working. Before the update it was working fine. I do not know how to fix it.
2014-01-21T14:44:09+00:00
Hey, I personally found this way for the 2 Finger-click to work out after searching for 4-5 months ( I am assuming your touchpad is Synaptics; as mine is) :
  1. To re-enable two finger tap, press Windows key + R, enter "regedit" then press enter, and on the left pane browse to the following location:
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadPS2
  1. In the right pane, double click on 2FingerTapAction and change the value to a "2" (Hexadecimal) for right click, or a "4" (Hexadecimal) for middle click.
  2. Double click on 2FingerTapPluginID and clear any value it may have.
  3. In the right pane, find the MultiFingerTapFlags key and change it from a 2 to a 3.
  4. Additionally, if you want to enable three finger tap for middle click, double click on 3FingerTapAction and change the value to a "4", also clear any value for 3FingerTapPluginID and set 3FingerTapPluginActionID to "0".
  5. Restart your PC and you can see the changes well enough.
Note: You should be careful enough while changing the keys in the Registry, as any deletion or wrong entry may create problems in running Windows.
Good Luck!
2014-02-02T16:45:55+00:00
To the above 'Jeet Das's answer, I'd like to add that on my Lenovo IdeaPad Y500, the settings that needed to be changed were under
HKEY_CURRENT_USER\Software\Synaptics\SynTP\TouchPadSMB2c
Thanks Jeet!
49 additional answers
    2014-04-28T08:05:14+00:00
    Your reply happened to be the closest that I've come to resolve my right-click problem.
    I have HP Envy Touchsmart.
    I tried your suggestion, however, I could only go as far as:
    There were only 3 files in the right pane:
    Default
    DisableDevice
    NotifyDriverFirstLoadState
    With that being said, I wasn't able to move on to the succeeding steps.
    Did I miss something? Are there other ways to solve this problem?
    Thank you :)
    2014-04-25T01:51:30+00:00
    Just upgraded to 8.1 and this solution worked for my HP Envy Sleekbook 4. Many thanks!!
    2014-03-08T19:27:21+00:00
    the problem is that the notification for the touchpad is turned off and you have to go into control panel>hardware and sound>Synaptics Touchpad v7.5 to change the defaults
