Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2015-12-15T14:19:58+00:00
    Thanks. I was giving up hope for a reply. Checking it out now
    2015-12-15T06:02:47+00:00
    Hi AlexDragu,
    Activation in Windows 10 works a little differently. If you have installed the big November update, you should be able to use your Windows 8 product key to activate Windows, if necessary - but you probably won't even need to do that, as your system should have a digital entitlement, which allows you to reinstall without having to re-enter a product key. See this article for more information.
    2015-12-13T19:06:11+00:00
    I have a Windows 10 Samsung laptop. Bought it with windows 8 upgraded to 8.1, formatted, back to windows 8, updated to 8.1 then to 10. ran really well for 3 months. Suddenly the processor speed stays from 0.76ghz-0.78ghz. Ran the power troubleshooter, made no difference. I cannot reinstall as for I have no disk or valid product key. The product key on the bottom of my laptop is for windows 8. All drivers are up-to-date and all updates are installed.
    System specs:
    Manufacturer: Samsung Electronics
    Windows Edition: Windows 10 home
    Processor: Intel Core i3-2328M CPU @2.20 Ghz
    RAM: 8gb (7.71gb usable)
    Computer name ****
    Full computer name ****
    Computer description
    Workgroup: WORKGROUP
    2015-12-10T02:27:10+00:00
    Hi Rodrigo,
    You can access the registry by searching "regedit" from Start.
