Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2015-12-15T16:46:06+00:00
    In Windows 10, there are recovery options that will let you reinstall without needing a disk. Go to Settings > Update and Security > Recovery and choose Reset this PC.
    The rest of your reply confuses me -- it sounds like your school Windows XP laptop is running at 99-100% even when doing nothing. Is it provided/maintained by your school? You may need to check with your school for troubleshooting options. You can also start a new thread in the Windows XP sectionto receive help from people who know more about XP than I do.
    2015-12-15T16:01:34+00:00
    thanks for the really quick reply.
    Can't reinstall. Don't have a windows 10 disk. I have all updates installed and run an antivirus scan every day.
    I've noticed that my disk is at 99-100% even when doing nothing. What is this caused by? by the way I'm doing this on a HP mini 5103 school SEA. It runs off of windows XP and is crumbling, so I can't get any information about it now. get back on any info about it over the weekend. Reply's as to how to get rid of this would be greatly appreciated ASAP. thanks
    2015-12-15T15:49:34+00:00
    I used to get this in Windows 7 sometimes. I'd check if you have any pending updates, or any antivirus scans running(Windows Defender, Norton, etc.). You could also check the Task Manager (right-click the taskbar and select it from the list) to see if any strange apps are running. If you don't have any pending updates or running scans, it should be fine to force the shutdown - when it happens again, click the button that says "Shut down anyway."
    Let me know how the reinstall goes and if it fixes your problem. After I did a clean install of Windows 10 on my laptop, I have never noticed this issue again.
    2015-12-15T14:23:32+00:00
    Just checked it out now. Thanks. I also have a problem where when I shut down, It says an app is preventing shutdown, but the app has no name. The name box is blank. It doesn't seem to affect anything, it's just annoying. Any ideas at to what this might be?
