My friend suggested that I take out the battery, plug the laptop in, and run it. Somehow (it sounds like it resets the drivers or something) this fixed the problem. I still can't believe it. Anyway, thanks for your suggestions!
Since that worked it probably indicates Lenovo has some sort of Power Options / Power Management
control in place which I have thought all along. And/or there was some sort of hardware or software
glitch which that cleared. If you put the battery back in does do the same thing? (It may even take
letting it sleep or hibernate once to energize that change if it is going to do so.)
The Lenovo Forums is likely to have others that have/had the same issue.
Glad to have helped. Sounds like you did some very good troubleshooting!
Moving everyday, going further on,
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle <- Mark Twain said it right!
