Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2014-08-06T16:39:07+00:00
    My friend suggested that I take out the battery, plug the laptop in, and run it. Somehow (it sounds like it resets the drivers or something) this fixed the problem. I still can't believe it. Anyway, thanks for your suggestions!
    2014-06-11T17:40:51+00:00
    Lenovo Support should certainly be able to tell you. Did you ask for more information?
    The DPTF Driver should be available from Lenovo.
    Check with Intel :
    Intel - Support - Community and Forums
    http://intelopenport.hosted.jivesoftware.com/community/tech
    Intel Download Center
    http://downloadcenter.intel.com/
    Rob - SpiritX
    2014-06-11T15:30:59+00:00
    One of the replies to my post in Lenovo Forums said that it is called Intel DPTF. I've looked everywhere for this, including in the BIOS. Any idea where I can find it so I can disable it? I've considered downloading the latest drivers from Intel just so I can have something to work with. Is that a reasonable approach?
    2014-06-10T19:51:32+00:00
    I added that to the thread. I was thinking of including it when I was creating the thread, but I couldn't quite find the right way to phrase it.
    Owen
