Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2015-12-30T20:36:06+00:00
    Hi danielgr,
    It sounds like your laptop was running normally on 8.1 -- is this correct? Also, if you haven't already, you should check for the latest drivers from Sony. Find the official support/drivers page for your specific laptop, and install any graphics or processor related drivers. If you are unable to find drivers specific to your laptop, you can instead try installing drivers directly from Intel.
    2015-12-30T20:09:02+00:00
    Have the same problem on a Sony Vaio Laptop, Sandy Bridge i5-2450M with AMD switchable graphics.
    I've tried everything I've found here and there, such as:
    • Start (and run it) without the battery
    • Remove the battery power manager in the devices manager
    • Searched for the famous registry keys (which are not there in W10)
    • Upgrade install (first), then fresh install (now)
    • Enable Hyper-V
    Basically, nothing is working, and my PC is locked at 0.78GHz, making it totally useless.
    I was actually ready to give up on my AMD graphics (which I knew was never going to work in W10), but ... having the CPU locked to less than 1GHz is a no go ...
    Since no-one seems to have solved this issue, I guess that I'll need to go back to W8.1 and forget about W10 for a while... Pretty sad indeed, but may well be one of the reasons why Sony had to give up on their PC business. They did build and design great products, but always offered the worst possible service, trying as hard as they could to lock you down into buying new ones.
    2015-12-15T17:54:00+00:00
    Alright. thanks, but how long will the installation take??
    2015-12-15T17:50:03+00:00
