- Hit Ctrl-Alt-Delete and open Task Manager
- Click on DETAILS tab
- Find explorer.exe, right-click, and click on END TASK
- On the top Menu Bar, click on FILE, RUN NEW TASK
- Enter explorer.exe in the task entry box and click on OK
- On the top Menu Bar, click on VIEW and REFRESH NOW
- Volume icon should reappear after refresh
Volume taskbar icon vanished / greyed-out in Control Panel
Since installing the latest major 8.1 update, my Volume Notification Area icon has disappeared. (It returned briefly but the default seems for it to inexplicably go away again to not return).
It still shows up as active when I go to Control Panel > All Control Panel Items > Notification Area Icons
But toggling this a bubble appears saying "This notification icon is not currently active"
Going then into "Turn system icons on or off", the Volume System Icon is turned off, and greyed-out for access.
Why would this happen?
I see old threads for this happening in Win7, and I'm wary of downloading a registry fix in case my 8.1 computer blows up.
I checked and my drivers are up to date.
The problem actually fixed itself as suddenly as it started... no idea what that was about.
70 additional answers
2014-05-06T18:54:20+00:00 Hi Elias,
Thank you for replying with the status of the issue.
I am glad to know that the issue is resolved.
Please feel free to visit our website for any help with Windows Operating System.
2014-05-05T22:03:41+00:00 I noticed the same exact issue recently on my desktop computer. The speakers and audio are functioning correctly, and if I play music via iTunes, I can change the volume using the iTunes controller. However, just like Elias01010, I no longer see the volume icon, and it is greyed out when I try to enable it. I know of no updates that any devices require. I get no error codes. It's a AMD Phenom quad-core 9850 computer, with an AMD Radeon HD 6570 video card, and 8GB of RAM. All was well prior to the 8.1 upgrade, and I can still use the computer, I just can no longer change the volume using the system icon.
-- Bill M - Bellevue, WA
2014-04-29T20:19:14+00:00 Hi Elias,
As mlg63 suggested, I would also suggest you to check the status of the sound card in Device Manager. If it requires you to install a audio drivers, then you will have to download the audio drivers from the computer manufacturer's website and then try installing it on your computer and check if it fixes the issue or not.
Also reply with the following information so that we could assist you further.
- What is the make and model number of the computer?
- Do you get any error code or error message while startup?
- Have you made any changes to the computer prior to this issue?
Please reply with the status of the issue so that we can help you better.
