- Hit Ctrl-Alt-Delete and open Task Manager
- Click on DETAILS tab
- Find explorer.exe, right-click, and click on END TASK
- On the top Menu Bar, click on FILE, RUN NEW TASK
- Enter explorer.exe in the task entry box and click on OK
- On the top Menu Bar, click on VIEW and REFRESH NOW
- Volume icon should reappear after refresh
Volume taskbar icon vanished / greyed-out in Control Panel
Since installing the latest major 8.1 update, my Volume Notification Area icon has disappeared. (It returned briefly but the default seems for it to inexplicably go away again to not return).
It still shows up as active when I go to Control Panel > All Control Panel Items > Notification Area Icons
But toggling this a bubble appears saying "This notification icon is not currently active"
Going then into "Turn system icons on or off", the Volume System Icon is turned off, and greyed-out for access.
Why would this happen?
I see old threads for this happening in Win7, and I'm wary of downloading a registry fix in case my 8.1 computer blows up.
I checked and my drivers are up to date.
The problem actually fixed itself as suddenly as it started... no idea what that was about.
70 additional answers
2017-10-24T18:45:26+00:00 It´s now 2017 and I just got the same problem. Everything was working fine and the volume control icon just disappeared. I´ve been through every option suggested here and elsewhere, including deleting the icons from the registry, restarting Explorer, etc., still no icon. When I check the options for system icons, the option to turn it on is turned off and greyed out.
I am using Win 8.1 64 bit. I tried updating. It shows that there are 14 optional updates, but when I click install, it sets at 0 of 14 to download for 20 minutes.
The Computer is an Asus F552W
AMD A4-5100 APU with Radeon HD Graphics
8Gb memory
