USB-IF xHCI USB host controller driver problem
2013-01-03T05:58:56+00:00
My new Windows 8 in Sony VAIO has detected problem with the driver for USB-IF xHCI USB host controller, which Windows couldn't reinstall. What to do? I haven't made the recovery disks yet! Please reply...
2013-01-06T16:12:49+00:00
I saw this post today and the information provided helped me fix this issue.
Click Here
http://www.eightforums.com/hardware-drivers/17161-intel-wiusb-driver-not-working-properly.html
The link basically says to visit the Intel website and use the Intel Driver Update Utility. The utility will automatically scan your computer for devices that are eligible for an update. Hope this helps you because it helped me. I also updated my Wireless driver while I was using the Intel Driver Update Utility since a newer driver was recently made available.
This worked for me; however, I ended up having to uninstall the old Intel WiDi driver and then restarting my computer before the setup.exe file would run and install on my computer (dell inspiron). I did create a restore point in case it didn't work, but everything seems to be running smoothly!
I should also point out that just deleting the Intel WiDi driver also got rid of the yellow exclamation mark, and unless you are planning to try and connect to your computer to your TV wirelessly, I don't think it is something that you need. Here is a link that explains what the driver does:
93 additional answers
    2014-11-27T10:17:27+00:00
    DID YOU EVER FIND A SOLUTION TO THIS PROBLEM ? I HAVE THE SAME PROBLEM / THANKS DARLENE
    2014-08-29T23:45:51+00:00
    You're welcome @FeliciaWhite. Thought I'd share my findings in case it helped. Sorry it wasn't compatible @BearlyAlive. Oddly enough in my case, it didn't fix the issue when I tried it the way you mentioned or through the driver update utility tool by Intel - but the download I found sorted it, no problem. Thanks for sharing and hope it worked out for you.
    2014-08-29T22:54:48+00:00
    Dear Caicah:
    FYI, I attempted to install this upgrade but it wouldn't install because it failed to find compatible equipment. Intel (via a training video) also indicates that the Windows OS should be able to find it by using the Devices charm on the right of your screen. It will download the necessary components if compatible equipment is found. Thanks again for your info.
    Sincerely,
    BearlyAlive
    2014-08-29T05:31:45+00:00
    thank you so much for the link Caicah!
