2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2016-02-11T16:33:26+00:00
    Ok I finally found it!
    So on the Windows screen go to settings.  It's the purple gear icon.  Or type settings in the search.
    >Settings
    >PC and devices
    >Mouse and touchpad
    At the very bottom of the page it says:
    "To help prevent the cursor from accidentally moving while you type, turn off taps or change the delay before taps work."
    Click the drop-down
    >Turn of Taps!!!!!!!
