2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-08-15T07:33:18+00:00
    I have a Dell laptop on Windows 8 and FINALLY found the way to disable tapping as follows:
    1.- Swipe on the right of the screen and select SETTINGS
    2.- Go to the bottom of the column and select CHANGE PC SETTINGS
    3.- Select PC  AND DEVICES
    4.- Select MOUSE AND TOUCH PAD where you can disable the touch pad, and better:
    5.- Go to the bottom of the page and select the drop down menu on tap delays and the last option there is nothing less than TURN OFF TAPS !!
