2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-07-14T23:34:25+00:00
    Dell Laptop with Synaptics pad under Windows 10. The Dell Mouse settings from the control panel GUI don't work; use regedit to turn off the default tap to click nonsense (why default?) as follows:
    1. Push the Windows Key + R and type "regedit" - click ok
    2. Navigate to:
    HKEY_CURRENT_USER\SOFTWARE\Synaptics\SynTPEnh\ZoneConfig\TouchPadPS2
    1. Find the value "Dual Mode"
    2. Change the value data from 1 to 0
