2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-06-27T13:20:20+00:00
    I turned off tap in error and need to turn it back on my windows 8 computer. How do I do this?
    Undo whatever you did.  If you have read this thread you would realize that that depends on your hardware and your manufacturer's support of it.  For example, on my Surface RT I found that it has something it calls a "Trackpad" but I had disabled its "mouse" using a method I have described in this thread but apparently will no longer have to do that because there is now an "app" for that which will be much easier to use to toggle the Trackpad off and on.  Thanks for making me see that!  Meanwhile with Win-w I see nothing informative by typing  tap click.   (I suspect some users with a Synaptics based Touchpad could have different results.  <eg>)
    Good luck
    Robert Aldwinckle
