2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-01-24T21:48:29+00:00
    With all due respect.  This is the canned response that keeps appearing on every forum.  Fact is, on many laptops there simply IS NO tab for tapping in any of the mouse settings or driver setup windows.  This is the reason I will be returning my laptop.  Not sure if it is the third party license ppl or microsoft itself, but to not give a use the ability to change a function of his laptop is just preposterous.  I cannot have my cursor jumping all over the place if I breathe on the trackpad.   Combined with several other extraordinarily ridiculous changes that have actually cost me money in work, I will be leaving Windows for good.  Good luck with this monstrosity, at least I figured out how to turn it off finally.
    If ANYONE figures out how to disable tapping on their trackpad, you may be on to a million dollar idea.
    I was as frustrated as you when starting to use a new Acer Aspire V.  All the methods that work on other PCs would not work for me.  I think it's due to a lousy driver.  Using charms search for "trackpad", a new window appeared.  At bottom a message said, "To help prevent the cursor from accidentally moving....turn off taps...."  One of the 5 options for selection was Turn Off Taps.  Problem solved after much frustration.
