2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2015-01-05T14:16:37+00:00
    I posted this nearly 2 years ago.  Over this time the Microsoft support has answered several times, cluelessly. If it weren't for the user who contacted me 21 months ago and let me know that it can take up to 5 minutes after booting for the proprietary application called  "SmartGesture" to load itself into the tray, I may never have gotten to use my trackpad at all.  Searching for this app will produce zero results,  it is bundled into a pack of other ASUS utils.
    The first response Microsoft gave was months after I posted this problem initially,  and it was totally incorrect.  After 2 years,  I am still receiving notifications of Microsoft CSRs telling me to type "Trackpad" into the search box.  If one of you  Microsoft guys had simply said, "ASUS models use something called 'SmartGesture'" then maybe I could say you were helpful.
    Unfortunately, none of you know (to this day,  apparently) what your own manufacturers do with your software.
    2 years.... how do you guys even accomplish a release?
