2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-11-12T02:42:01+00:00
    Aserian, mine synaptics touchpad was even easier, I followed our advice, but when I click on the little touchpad icon a small box opened with "touchpad setting" and "tap to click" which I unchecked and now it's turned off. Thanks for the help with finding this.
