2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-10-04T14:28:20+00:00
    On my ASUS laptop, I had to disable this by going through the "ASUS Smart Gesture" program. The icon for this is in the taskbar dock. Click the little up-arrow to expand it, then double click on the ASUS Smart Gesture icon. The option to turn off "Tap to select" is under the General Gesture tab. There wasn't a Synaptics or ELAN pointing device icon for me, but I could change the tap setting there. Hope it helps some others.
