2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-04-17T17:50:31+00:00
    I was getting mad with the cursor of my brand new ASUS T300L flying all over the screen and the Fn+f9 key not working. I disabled the touch pad from Control Panel>Mouse>Asus Touch Properties>Change Settings and... voilá! Fn+f9 started to work!!
