2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-03-27T14:27:01+00:00
    Control Panel > Select "Mouse". "Mouse Properties" should be displayed. Select the tab "Device Settings".
    Devices are listed in a table below.
    Double click device name displayed under "Devices:"
    For me I see a new window called Synaptics Control Panel.
    Here there is a section under "One finger" called "Tap".
    Under Tap there is a checkbox called "Enable Tapping". Uncheck that checkbox. Select OK.
    I have the same problem as OP, and there is no checkbox next to "One Finger > Tapping." I have an Elan touchpad. If I click the question mark button, it says something along the lines of "Tapping always serves the same function as the left mouse key;" there is simply no option to turn it off from that approach. Is there a way to disable it without the Elantech settings?
