2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-03-13T14:39:08+00:00
    I installed Win8 on multiple computers and find that "tap to click" is turned on by default. Win8 doesn't seem to have a built-in method to turn it off, it's usually 3rd party. Win8.1 does seem to have a built-in option. So here are my suggestions in the order I would try them to solve the issue.
    1. Upgrade to 8.1 if you can (it also has other features that are helpful)
    2. go to control panel and search for mouse, the touchpad driver may be integrated to the controls in which case you'll have a tab for touchpad (it maybe controlled there or have a link to take you to another window)
    3. Look for an icon on the right side of your task bar (may have to click the arrow to show all icons because by default they aren't shown). Then righclick on the icon that looks like a tracerpad (rectangle with two small rectangles below it)
    4. use file explorer to search for "Alps" or "Symantec" but make sure you check the box for "hidden files" or it may not come up. doubleclick to execute the file. I also save a shortcut to my desktop because many times windows upgrades override the settings and turn "tap to click" back on. with the shortcut on my desktop, i can easily access it again if it doesn't stay resident in the taskbar as an icon.
    5. use file explorer to search for "touchpad" and see if you can find an application file. For instance, Dell has the "dell touchpad" and I believe some others also their own version of files. If you can't find anything try similar words like "tracerpad."
    Once you have the icon on your taskbar, just rightclick and you may get the option to disable tap or an option to open a gestures menu.
    Hope this helps someone. i know the "tap to click" drives me crazy.
