2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-03-13T12:44:44+00:00
    Hi ive tried this and other peoples quotes to help also but to no avail, same problem as when im typin my hand hits the mousepad and goes to where cursor is and starts typing there, I have a samsung v50 on windows 8, but when i click control panel, i dont have mouse and device settings for a start i search for mouse and even then i dont have the vast options you have listed, only: Buttons, pointers, pointer options and hardware so i dont have the added touch pad option there either, please help - its driving me mad. Daisy.
