2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-15T19:32:43+00:00
    I know - I don't have a Dell, and I haven't verified this, but I read that Dell does not use Synaptic trackpads.  I don't know what they use - that is why I specified Synaptic.
