2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-15T19:26:13+00:00
    Thanks,, but new Dell running Windows 8 does not have the usual procedure available.  I figured it out though.  The only way to do it is find the hidden icons at the bottom right of the screen, click on Touchpad, and go from there.  It took me a while, but I finally noticed it after a couple of people on here mentioned it with their ASUS or other computer.  Thanks though.  That might help someone else.
