2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-10T16:54:04+00:00
    thank you, i appreciate you trying to help, but it isn't fixable on this laptop. searching "trackpad" from the start screen produces no results, neither does "touchpad", "clickpad", or any related words.  the drivers do not give the user this power.  it can't be done, literally. thanks.
