2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-09T22:01:04+00:00
    Go to your Device Manager and go to the Mice and Other Pointing Devices.  Disable the Synaptic Driver.  Then go Control Panel/Hardware and Sound/Synaptics TouchPad and uncheck all boxes.
