2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-15T17:35:37+00:00
    YYYYYYYESSSSSSSSSSSSS!  Thanks to the two of you who said to go to the bottom right corner and find an icon beside the volume!!!  My Dell had a little arrow to click for hidden icons, and VOILA, there it was.  I was able to get into the touchpad properties.  Man, they really should have put that under devices, too.  Thank youuuuuuu!!!!!!!!!!!
    Hope the original poster found this out, too!
