2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-15T13:56:21+00:00
    I feel your pain.  This is maddening.  There seems to be no way to disable "tap to click".  Not sure why people keep suggesting disabling the touchpad as a lot of us do not wish to use an external mouse.  I hate them.  I like a touchpad that can be changed from "tap to click" to just regular manual clicking.  Every other laptop I have ever used has had that capability.  Tap to click should not be the default!!
    Did you figure it out, or is it not possible as I suspect?
