Problem with wireless adapter or Access point
2013-02-01T11:09:56+00:00
I am having problems with my wireless connection and troubelshoot tells me that I have a problem with the wireless adapter or access point. What can I do, as the internet is not the problem. Does this have something to do with my PC setting?
    2017-11-26T01:33:34+00:00
    https://youtu.be/YTWjfT7X5YE
    This should help above sorry forgot to hyperlink
    2017-11-26T01:32:21+00:00
    If your wireless keeps dropping in and out this solution should help below
    2017-11-14T19:44:32+00:00
    i have dealt with this issue recently and the fix i have found is to reinstall windows.
    2017-11-14T18:46:11+00:00
    funny but how did they get online to send a question.  Sorry Shawn,,, you are better then I the way I would have replied to them.
    2017-11-12T16:25:37+00:00
    Network adapto not detact
