fsdfgsdf
Problem with wireless adapter or Access point
I am having problems with my wireless connection and troubelshoot tells me that I have a problem with the wireless adapter or access point. What can I do, as the internet is not the problem. Does this have something to do with my PC setting?
2017-10-11T15:25:36+00:00 -
@CmdrKeene 90,631 Reputation points Volunteer Moderator2016-10-17T21:09:33+00:00 There's two ways to Block Unwanted Updates in Windows 10. You can hide an individual update being offered in the Windows Update list (one that is nearly ready to install but hasn't been installed yet). The 2nd option is to Block Automatic Driver Updates, but Keep all other updates.
Deleted
2016-07-08T00:30:58+00:00 This was what solved my problem:
http://www.registryrecycler.com/blog/2013/11/fix-wi-fi-connectivity-issues-in-windows-8-1/
It's actually a very useful page containing many of the solutions found here. I went through each solution one after the other, and by the fifth solution, my Wi-Fi was up and kicking! :)
@CmdrKeene 90,631 Reputation points Volunteer Moderator2016-05-02T01:14:33+00:00 I don't think it's likely to be the cause either, just something mfg'r recommends for that model after upgrade. I'd actually use that page to grab their driver and install it. Even if it matches the version you already have installed, so you're using the one they tested and not whatever got installed from WHQL over Windows Update.
