How do I delete huge files from System Volume Information?
2011-08-16T11:37:52+00:00
I have three large hard disks that I use to store backups of the system.  Some program -- I think it was the defragmenter -- caused Win 7 to place huge files (> 4 GB) in System Volume Information.  Nothing I do wil let me delete these files.  I cannot even take ownership of them.  When I try to take ownership of either the file or of System Volume Information I receive an "Access is denied" error on the file name.  Nothing should prevent an administrator from taking ownership of any file on his system.  How can I delete these huge files?  Please do not answer "Use Disk Cleanup to delete all but the last restore point."  That runs, but it deletes nothing.  On a previous installation of Win 7, I could take ownership of System Volume Information and delete its contents, but ot on this new installation.
2011-08-17T10:05:51+00:00
The System Volume information folder keeps the Restore point entries. Usually it is not recommended to delete the entries from the System volume information.
Step 1 : Stop the Volume shadow copy service.
a:  Go to Start - Run and type Services.msc then press enter.
b: Under the Status column look for any entries that read as "Started", make it as “Stopped”.
**c:**Click apply and then ok.
Step 2 : Then take ownership of the System volume Information folder and then try to delete its contents.
How do I open a file if I get an access denied message?
Hope that helps.
47 additional answers
    2016-02-17T18:58:59+00:00
    your method is by far the essayist way to complete the task thank you very very much hope you all the best
    2016-01-21T19:56:13+00:00
    Volume Shadowing was disabled on my server and couldn't figure out why it was still taking snapshots.  I ended up following the article below to delete the shadow copies.  It didn't give me the delete option but I went into settings and limited the space that Volume Shadowing can use to 500MB and that freed up tons of space.  Good luck
    https://technet.microsoft.com/en-us/library/cc776119(v=ws.10).aspx
    2015-08-27T10:51:21+00:00
    I have just cleared 30GB from a drive on a W2008 server by running chkdsk (Error Checking) from the properties, tools (I actually deselected "automatically fix system disk errors").
    2015-07-13T11:06:45+00:00
    Using cCleaner to selectively delete restore is a better approach. Paragraph 4.16:
    http://www.gerryscomputertips.co.uk/maintenance4a.htm
