Change mouse double click to single click
2011-02-23T20:16:22+00:00
How do I change the mouse click from double to single?
  • Looked in Control Panel under "Mouse"
2011-02-23T20:24:24+00:00
Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
2011-02-24T01:34:50+00:00
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
2011-02-23T20:22:38+00:00
Do you want to always use a single click to open files, run programs, etc?  If so:
  1. Go to Control Panel > Folder Options .
  2. Under Click items as follows , select one of the Single-click options.
Boulder Computer Maven
Microsoft Most Valuable Professional
74 additional answers
    2018-10-17T01:58:25+00:00
    I finally found how to switch from double to single click in Windows 10. Go to Control Panel. In the search window type Double-Click (remember the dash). A window will open with the link to switch. Click it and the window you want will open. Long Live Single Click!
    2018-10-16T09:27:30+00:00
    thank you thank you you would think it would be under mouse settings
