Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
How do I change the mouse click from double to single?
HTH
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
Do you want to always use a single click to open files, run programs, etc? If so:
were is the START button
Just want to point out this only works for 1/2 of the window in windows 10. The left hand portion that has "quick access" does not support this. So if you want to remove several references from quick access at the same time you cannot select more than one file.
