Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
How do I change the mouse click from double to single?
HTH
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
Do you want to always use a single click to open files, run programs, etc? If so:
When you arrive at the Control Panel, you will NOT see Folder Options. Go to the upper right corner of the screen and type Folder Options in the search window. The Folder Options windows will open.
I agree that "common sense" needs to be used to a much higher degree when deciding where to place options. Windows users shouldn't have to search all over, trying to guess where some Microsoft tech-nut decided to hide something as common as mouse settings. Most of us aren't novices and we get quite frustrated with upgrades and new Win versions, especially when things get moved around and placed in areas that don't make sense - to us anyway. Again, if it's not broken, please don't try to "fix"it. Thanks again to all y'all for your most helpful input! What would we do without these forums?
