All you actually had to do and I know this is a late late reply but its just in the case of letting you know how easy it really was to fix this issue what you should have done was turn the internet system icon off and back on that's what fixed this issue for me....
Red X on system tray connection icon even though I am connected to the Internet. OS is Win 7 64 bit, how do I correct this.
Red X in system tray connection icon...have reset router, restarted computer...how to correct this problem
Try this. It worked for me.
I finally removed the security from my network and the network status now shows me as connected. The red X is gone. It seems that Windows 7 does not support WPA2-PSK. I cannot imagine that is the case. Any ideas as to why, as installed on my PC, it does not have an option for WPA2-PSK? As I said, the hardware is supported and previously worked with XP.
61 additional answers
2011-08-10T22:53:02+00:00 no it doesn't.
If you have the incoming connections enabled you'll still see the damn red cross and micro$oft still doesn't give a $hit.
2011-03-21T17:13:56+00:00 Try this. It worked for me.
What if you don't want to remove the security from your network?
2010-09-02T00:53:32+00:00 It only works for a few people with out-of-date drivers.
