When using my microphone, the microphone level automatically adjusts.
2009-11-14T15:52:58+00:00
In order to fix it temporarily I have to right click the speaker icon in the tray, go to recording devices, double click my mic, go to the levels tab and readjust it. It becomes a huge problem when talking with the mic and the level goes from 100 down to 20 randomly and all of a sudden I can't be heard.
Sometimes it goes down right away, and I don't see a checkbox to disable this automatic adjustment.
I have unchecked allowing applications to take exclusive control but I'm not sure this is actually related.
2010-10-24T12:30:47+00:00
This has also had no affect on the problem.   Again I knew this would not help.   You see,  the above suggestion merely stops communications software adjusting the volume of other software items.
This problem is not related to the output volume of software being auto-adjusted.   It is to do with theinput level (sensitivity) of the microphone being auto-adjusted.
To try and clarify where the problem lies,  the input level that you see when you right click speaker icon,  select 'Recording Devices',  click the 'Recording' tab,  select the 'Microphone' and click 'Properties',  then click on the 'Levels' tab.   It is the 'Microphone' level there that is auto-adjusting.
Please note that this problem is related to the Microphone Input level.  Not a volume output level.
2010-10-30T12:05:40+00:00
Hi gerri,
To further clarify, are you saying that the volume slider in the microphone properties (pictured below) is auto-adjusting:
If yes, do you see the slider moving on it's on?
If yes, this is not a function of Windows 7 that I am aware of.
I suggest uninstalling Skype temporarily and restarting the computer to see if the issue resolves.
Chris
61 additional answers
    2013-07-04T02:11:49+00:00
    I also have this problem, I do not have skype or windows messenger installed this is a pain for me as I am a youtube recorder
    I have the following installed that uses the microphone
    Steam
    Teamspeak
    Dolby Axon
    Audacity
    Windows Movie maker
    Sony Vegas
    Fraps
    2013-06-24T15:41:11+00:00
    No , Skype has nothing to do with auto microphone level adjustment .   You have an option "allow applications to have exclusive level control " , disabling this option is absolutely useless , level is adjusting in auto mode and what is worse only to 0 , just shutting down .
    2013-05-23T00:27:41+00:00
    I tried your advice, but it still continues to adjust my microphone level.
    Please help?
