When using my microphone, the microphone level automatically adjusts.
2009-11-14T15:52:58+00:00
In order to fix it temporarily I have to right click the speaker icon in the tray, go to recording devices, double click my mic, go to the levels tab and readjust it. It becomes a huge problem when talking with the mic and the level goes from 100 down to 20 randomly and all of a sudden I can't be heard.
Sometimes it goes down right away, and I don't see a checkbox to disable this automatic adjustment.
I have unchecked allowing applications to take exclusive control but I'm not sure this is actually related.
2010-10-24T12:30:47+00:00
This has also had no affect on the problem.   Again I knew this would not help.   You see,  the above suggestion merely stops communications software adjusting the volume of other software items.
This problem is not related to the output volume of software being auto-adjusted.   It is to do with theinput level (sensitivity) of the microphone being auto-adjusted.
To try and clarify where the problem lies,  the input level that you see when you right click speaker icon,  select 'Recording Devices',  click the 'Recording' tab,  select the 'Microphone' and click 'Properties',  then click on the 'Levels' tab.   It is the 'Microphone' level there that is auto-adjusting.
Please note that this problem is related to the Microphone Input level.  Not a volume output level.
2010-10-30T12:05:40+00:00
Hi gerri,
To further clarify, are you saying that the volume slider in the microphone properties (pictured below) is auto-adjusting:
If yes, do you see the slider moving on it's on?
If yes, this is not a function of Windows 7 that I am aware of.
I suggest uninstalling Skype temporarily and restarting the computer to see if the issue resolves.
Chris
61 additional answers
    2013-04-24T07:23:10+00:00
    I found the problem was Skype, Skype automaticly adjusts audio levels to suit the caller. To fix this go into Skype then Call on the bar at the top left then Audio Settings... and click automaticly adjust microphone settings. i found this stopped the levels from dropping
    2013-01-11T13:22:45+00:00
    help.  I am having this problem too.  Every time  I go to record narration on my Dell Computer - the levels go up to 80 and I have tried everything but the reg edit ...which frankly makes me nervous to try....will have to get a service guy in for that.
    The result is a blasting sound that wrecks my recording.  I have a MAC and it is not happening on that computer at all.  But need this for work.
    Did anyone have success uninstalling Skype?   I don't use Windows Live Messenger but does anyone recommend uninstalling that?
    2012-12-31T19:02:48+00:00
    I found out that Windows media player was the problem for me.  Once I closed that program I have no problems.  I can't for the life of me find the option within WMP that controls this though.
    In Skype, google talk and other such programs there is an option for 'automatically adjust microphone levels' that can be turned off.
