See all 3 power plans on system tray
2009-10-01T03:29:27+00:00
Windows 7 is better than Vista in so many ways, but it's actually a lot worse in some others. Take, for example, choosing power plans from the system tray.
In Windows Vista, you could click on the battery meter and choose between the 3 plans: High Performance, Balanced, and Power Saver.
Now, for some idiotic reason, Microsft decided to limit our choices to only TWO plans from the system tray: your current plan + Balanced (if balanced is selected I believe it defaults to Power Saver for the 2nd one). To change it to the 3rd one I have to actually click on "More Power Options" and then select the plan.
Microsoft is requiring you to take extra steps for doing something that was easier before. I thought Windows 7's mantra was "do things faster" (i.e. Jumplists, Aero Peek, Accelerators, etc.) Who was the moron who made this decision, and how can I get my Vista-style Power tray back?
2009-10-03T17:27:31+00:00
Um maybe if you read my original post (or if use Windows 7 itself), Balanced is ALWAYS shown, even if it wasn't your 'old' plan. So you can't flip-flop between Power Saver and High Performance, which is what I want.
What if I deleted the Balanced power plan? Is there a way to delete the default plans?
Yes, there is a way.
FlyoutAutoPowerScheme: http://technet.microsoft.com/en-us/library/cc749282(WS.10).aspx
Rating posts helps other usersMark L. Ferguson MS-MVP
46 additional answers
    2014-11-13T17:03:09+00:00
    You will have to configure that feature for yourself. Create a new shortcut you can pin on the taskbar (or a toolbar folder with several shortcuts.) Put the command to set the active power scheme you prefer. To see the syntax of the powercfg utility, open a command prompt and run the command: powercfg /?
      -SETACTIVE, -S
                  Makes the specified power scheme active on the system.
                  Usage: POWERCFG -SETACTIVE <SCHEME_GUID>
                  <SCHEME_GUID>  Specifies the scheme guid.
      -GETACTIVESCHEME
                  Retrieve the currently active power scheme.
                  Usage: POWERCFG -GETACTIVESCHEME
    ![](http://i3.social.microsoft.com/Image.avatr?size=Large&amp;user=Mark L. Ferguson&amp;id=fb4a4625-6789-43eb-aa48-4a1fbf2df947)<moron helping to design Windows 7
    Brillian solution - I had used an app to do this, but was concerned when I saw the executable do something...curious, let's say. But your way is dead simple - create a new toolbar to a Desktop folder called Power - create three shortcuts in that folder (High, Balanced, Power Saver) to powercfg /s <GUID> using the appropriate guids from your system. Quick, no UAC prompts, and nothing extra installed. Kudos, sir.
    2014-01-02T11:51:49+00:00
    I recently made this simple app to get around this.
    https://powerbuddy.codeplex.com/
