See all 3 power plans on system tray
2009-10-01T03:29:27+00:00
Windows 7 is better than Vista in so many ways, but it's actually a lot worse in some others. Take, for example, choosing power plans from the system tray.
In Windows Vista, you could click on the battery meter and choose between the 3 plans: High Performance, Balanced, and Power Saver.
Now, for some idiotic reason, Microsft decided to limit our choices to only TWO plans from the system tray: your current plan + Balanced (if balanced is selected I believe it defaults to Power Saver for the 2nd one). To change it to the 3rd one I have to actually click on "More Power Options" and then select the plan.
Microsoft is requiring you to take extra steps for doing something that was easier before. I thought Windows 7's mantra was "do things faster" (i.e. Jumplists, Aero Peek, Accelerators, etc.) Who was the moron who made this decision, and how can I get my Vista-style Power tray back?
2009-10-03T17:27:31+00:00
Um maybe if you read my original post (or if use Windows 7 itself), Balanced is ALWAYS shown, even if it wasn't your 'old' plan. So you can't flip-flop between Power Saver and High Performance, which is what I want.
What if I deleted the Balanced power plan? Is there a way to delete the default plans?
Yes, there is a way.
FlyoutAutoPowerScheme: http://technet.microsoft.com/en-us/library/cc749282(WS.10).aspx
Rating posts helps other usersMark L. Ferguson MS-MVP
46 additional answers
    2011-03-03T19:43:55+00:00
    The Solution is so easy & i have it's a gadget you can change power planes within on touch
     http://gallery.live.com/liveItemDetail.aspx?li=e0040b09-c1c8-4ad0-b2a4-a3efc8fa850f&bt=1&pl=1
    2010-12-19T09:37:42+00:00
    Finally found a solution.  Get it here .  Its called Powerplan Assistant 7.  It is free [donationware] and it fixes this stupid problem.  I just installed it and think it will do the trick.
    I know installing another program to fix something Microsoft never should have done in the first place blows but until they fix it... this is all I could find.
    2010-11-27T16:33:33+00:00
    Firstly, I'd like to add an emphatic bump. Seriously--this is a dumb, tiny issue that shouldn't be a problem to fix.
    As a workaround: use the windows+x shortcut to bring up the mobility center, then choose your power plan from the dropdown menu. It's not a perfect solution (or even that great as a solution) but it seems to work faster than using the taskbar clicking ____.
    Anyway, this needs fixing. This shouldn't be something we have to go to 3rd party apps for. I'd take a registry tweak, but I haven't found one yet...
    Oi.
    ooh, didnt know about the windows-x key combo - nice :)
  4. Deleted
