Printer problem - Items sent to print are not printing.
2010-09-04T04:54:31+00:00
I'm having problems with my printer.  If I send a document over to be printed it doesn't print?  There's no jam, the cartridges are full and there's  paper.  Help!
2011-07-01T21:28:02+00:00
Hi Bob,
Getting a test page out is good start, but there a few thing s you can try to get your printer fully working...
Microsoft provides a Fix It tool which will troubleshoot the printer for you, and might give some useful information on what might be causing an issue:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
If you are getting prints out it sounds as though there isn't much wrong with the spools service, but keep an eye on it as sometimes a print job can throw the service out. You'll find it in Services.
Also, make sure you have the latest driver for the printer from the manufacturers website. You view what drivers you have already from Print Management, which you can find in Administrative Tools from the Control Panel.
Hope some this helps.
96 additional answers
    2012-07-27T15:48:39+00:00
    It says my printer is offline . how can I put it online
    2012-05-28T05:23:41+00:00
    After many tries I found out that Windows-7 will not let HP Officejet 4315 All In One printer work on my computer. It is not supported. I really like Windows-7, but a lot of older printers will not work with windows-7
    2012-05-10T14:38:36+00:00
    This scan did not show any problems.  I also have run the other suggestions and nothing helps.
    2012-05-09T16:52:44+00:00
